bebekhijau
Is bigrock 3s standard mounting motor plate support 42mm diameter motor ? ( standard motor is 36mm )
Yes it will fit. There is more than 3mm of clearance under the stock motor.I was going to say no. As I think it’d hit the chassis as the stock is close. Thinking about it, I can’t be sure right now but you’d need three millimetres of clearance at the bottom of stock and I don’t think it has that. Unless you cut part of the chassis away I’d be interested to know this for sure as well. sorry can’t be more helpful.
