GaryC
The motor shafts on a Hobbystar 3674 2650kv are bigger than the stock motor shafts right? 3s typhon?
Both should be 5mm.The motor shafts on a Hobbystar 3674 2650kv are bigger than the stock motor shafts right? 3s typhon?
Got a pic of it?The stock pinion isn't fitting the new motor shaft
Yes , just on the flat side of the shaftWhat did use? like the grinder wheel?
