Slicktmi
Hello so i have a issue with my new outcast have about 15 batteries through it im running 4s on my outcast with stock gearing and it gets up to 200 sometimes with mild bashing i checked for resistance and gear mesh all the necessities and everything checks out the esc never goes past 110 i vented my tires so there's no excess weight from dirt ect in there the battery is a 45c 4500 mah run time is around 15min so I'm trying to figure out why? i even switched to the 16t pinion thinking it was under geared and it got hotter so what do you think? Also ambient temp is in the 50 and under i took off the mud guard's made no difference the lipo temp after a run is about 120ish and also since im here what motor upgrade do you guys recommend for the outcast that runs good and cool on 4s that can be geared high im not looking for bandaid cooling fans just because that's kinda ignoring the real problem.
