- San Antonio, TX
- BigRock 4x4
- Granite
- Kraton 6s
- Kraton 4s
- Notorious
- Outcast 4s
- Typhon 3s
- Vorteks
- Voltage
- Infraction 4x4
(Figure I’ll put this under the 4s Outcast since many of the parts came from that car off of jennys.)
Ever since I built up Old Yeller (typhon/big rock mutation) nearly a year back, I’ve wanted to further modify it into a full 4S car. The wider footprint and bigger tires are probably the two main driving factors. I want to fill that niche between my 3S cars and 6S cars.
Once the new Kraton and Outcast hit Jennys I bought all the parts needed. Before my surgery I tore down Old Yeller and cleaned up the parts I intended to use again. I am going with the big rock/typhon long wheel base chassis and many of the stock parts from the new 4s cars. I’ve got a spectrum 130amp esc and new 4S motor off Jenny‘s that I’ll start off with (I have an MM2 esc and 4068, 2650kv surpass to install later on). M2C motor mount/brace, Amazon special 35kg servo and kimbrough servo saver, alloy steering rack, outcast 4s metal spur and diff for the rear, older style CNC diff for the front. New 6s shocks off Jenny’s from a Kraton top it all off.
I’m not sure if the existing body mount holes will work. If not, I’ll just get the exact same body and redo it the same way since I love how it turned out. For tires I went with a set of 4s Copperhead 2s. I like the full-size copperheads on my Kraton so figured they would work for this build as well.
Here is old yeller in 3S form. It’ll probably take me several weeks to do this while I’m recovering from surgery… but it will keep me busy at least
