5690 6s gearing
To bad it cost so much to ship to you.i got a good enough for bashing pps I'd give ya..what's tire size I assume 4.3 diffs...6s an what top speed ya want it to reach an I'll guestamate a good gearing with my usely very accurate calculator
I’ll print you a label if you wanna do that. Grown up a lot from back in the day😂. Got a job and everything now
Exb diffs. Mostly wanna bash. Full-size backflips
My calculator says a 1650kv motor with a 20t pinion and a 1250kv motor with a 26.4t pinion will have the same top speed. The formula is far from perfect, but it's good enough for establishing a starting place.
56 series mount won’t work either?
I’m not 100% but I don’t think so. I believe you’d need the whole Lim V2 motor mount plus the 56mm mounting plate for it. I don’t think the 56mm plate fits the stock Outcast motor mount.
Hey guys I have an Outcast EXB and I have the 5690 Max 6 combo. Yes I got the 1250kv on purpose but I am struggling on the gearing. I was thinking 26t pinion and keeping the stck mount for now? I will be running 6s for now. No 8s.
Arrma 56 series motor mount
Pinion?
I have a kraton exb v2 with max 6 5690.6s I run 22. Tooth pinion more than enough 60+ mph punch set to 7 I also run m2c everywhere center diff 1 million rear 200k front 100k all metal diff cases
I really appreciate it. Currently I have a 28t in there and I’m thinking it might be too large. I haven’t gone on a full bash yet. I can easily check motor temps through the app. What motor mount are you using and what centre diff? I’m using the limitless mount so 28 is the smallest I can go with a 57t diff
Running a M2C motor mount and center diff carrier all stock diffs 100k/1MK/200k stock spur. I can't even imagine a 28t. I ran a 19 at first and it was so much torque It was uncontrollable I think I will stick with 22t for winter months if it runs to hot in summer will drop to 21 or 20. I also would highly recommend Sagacustomrc gears they are wonderful
