Definitely not disagreeing with you.I'm by no means an expert and I love to learn. No ego here. I'm always open to suggestions!
ET48 2.0 weighs 10.8 lbs (w/ out battery). With the 5s Hobbystar battery, it's 12.2 lbs. Tekin T8 GEN3 ESC is capable of 300 max amp draw. Tekin T8 Truggy Motor is prob capable of 210 amps, max.
Theoretically, if the ESC/ motor combo can pull let's say "200 amps max," can a 5200mah 13C battery provide enough amperage without becoming damaged from "overdraw?"
Figure, (5200mah x 13C)/ 1000 = 67.6 max amp rating. The Hobbystar battery probably isn't far off that 13C. Even if it was 30C, that would still be less than the amount of amps the ESC/ motor would ask for.
What do you think,
@K-BASH? Did I do that math correctly?
