Atsuji-Chan
New Member
Hello! I am looking to add addressable 5v LED strips to my 3S Typhon. I will be using an LED Bluetooth Receiver which can connect to my phone to program LED patterns. The receiver has a barrel connector for power input and can passthrough that power to the LED strips. I will be plugging an adapter into the RC receiver, cutting the ends off and connecting it to a barrel plug adapter for the Bluetooth receiver. This will connect to the LED Bluetooth receiver and then to the LED lights.= which are IP67 rated and will be connected to each other through more weatherproofed cable and silicone sealant (I like to ride in the water)
What is the output voltage of the slr300 spectrum receiver? Is it 5v? If it not I can use a voltage regulator with a heatsink to feed a constant 5v to the LED bluetooth receiver. Also what is the amperage it can output? I'm going to be using at least 15 5V LEDs which the manufacturer claim will draw about 5 watts max but most likely will be drawing less because I will be using one colour at a time.
And assistance or ideas are appreciated.
