- Thread starter
- #21
So the inside of the rear diff housing was actually fine. No sand (or metal shavings) except the internal gears felt a little crunchy. I opened up the diff case, and found... a blown bearing. Found the inner and outer race, but no balls. Cleaned the diff out completely, ran a nail inbetween each tooth on each gear. Nothing. Maybe they were ground up, and mixed in with the oil?
Anyways, I cleaned all the old oil out, put a new TRBRC bearing in, and filled it with 30k traxxas oil. Don't be mad.
Here's a closer look at the custom driveshafts. Maybe I need a pair for the front, if that would work...
