6s ESC fan options
olds97_lss
Bash Break Repeat!
Dekalb, IL
  1. Kraton EXB
  2. Outcast 6s
I've used these and they work fine:
https://www.amazon.com/gp/product/B0782RHV3T
Buddy of mine was breaking them frequently in his talion and I found those after he paid $12 for the stock fan 3 times. They held up just as well and pushed a decent amount of air.
Oddly, I'm still on my original fan in my outcast, been over a year.
slick2500
Community Leader
ArrmaForum Fan
Rapid City, SD
  1. Kraton EXB
  2. Outcast 6s
  3. Senton 3s
  4. Typhon 3s
crimsonfancy
A guy that won't give up easily.
South Louisiana
  1. BigRock 4x4
  2. Granite
  3. Kraton 6s
  4. Mojave
  5. Notorious
  6. Talion
  7. Typhon 6s
The plug is different?
lol. Ok. Other than that?
Still a great savings for sure. Funny it's my Talion that needs one too and I halfass rigged a 30mm in there for the time being. I forgot about it but noticed again today and want to get it back to a cleaner fix.
olds97_lss
Bash Break Repeat!
Dekalb, IL
  1. Kraton EXB
  2. Outcast 6s
I did have to solder new ends on all of them. Found it best to peal the sticker back and use a fine tip iron to remove the wire completely and add a jst/servo type plug/wire on it so I didn't have to use heat shrink to cover a splice. Any time you splice a wire, it makes for a spot that work hardens and is prone to cracking as the wire flops around when running. So I try to avoid splices when possible.
