6s esc fan question
Lil Dylan
Houston, TX
  1. Notorious
  2. Talion EXB
Noob question here:
I bought a used Noto with stock electronics. I've been driving for a few weeks now and I've never heard the fan come on once. I don't beat the crap out of it but my other Hobbywing XR8 g2 fan is on all the time. Is the Spektrum fan supposed to be on all the time or does it come on at a set temperature and I'm just not hitting it? Thanks.
LicketySplit
Space Shuttle Door Gunner
Miami, FL
  1. Limitless
  2. Outcast 6s
Just to confirm, the stock fan should run all the time?
They’re quiet. Like really quiet since they don’t move much air. You said you don’t hear it so that makes sense. Rip the car around a bit and then pop the lid and see if it’s running.
Tex Koder
2D , 3D Not a problem. I'll take that Challenge.
Dallas, TX (USA)
  2. Infraction
  3. Kraton 6s
  4. Mojave
  5. Senton 3s
  6. Vendetta
Yes, it should be ON when you turn it on.
So it's probably dead as a doornail.
You should look into getting a 35mm to 40mm fan Adapter so you can install a much better Fan!
Lil Dylan
Houston, TX
  1. Notorious
  2. Talion EXB
Darn, it's dead. I'm going to replace it then sell the esc/motor combo as I have a HW combo coming in. Any idea what a used 6s combo should sell for (with new fan)? Thanks everyone
jkflow
TB RC Bashers
Hospitality Award
Tampa, FL 🇺🇸
  1. Infraction
  3. Talion
Check the classifieds here.
Actually love those ESC way more than the HW, but your call.
You can simply buy a 30mm alu frame fan, just installed one today in mine, fan blade was broken.
Slight modification to the fan cover, but works just fine.
RCbuzz
  2. Kraton 8S
  3. Kraton 6s
  4. Mojave EXB
  5. Senton 3s
Replace the fan and bash on! Then you have a hobbywing spare. I have replaced so many esc fans... :cool:
Tex Koder
Dallas, TX (USA)
  2. Infraction
  3. Kraton 6s
  4. Mojave
  5. Senton 3s
  6. Vendetta
35mm to 40mm Adapter (installed on Top of stock ESC casing.)
This is with the Casing Delete Raiser (if you want Maximum air flow.)
parcou
Hospitality Award
Rig of the Month Winner
Memphis, TN
  1. BigRock
  2. Felony
  3. Fireteam
  4. Granite
  5. Infraction
  6. Kraton EXB
  7. Talion EXB
  8. Typhon TLR
  9. Vorteks
Noob question here:
Keep the ESC as posted until or if it ever dies and get a good fan. Stock fans suck... Tex makes good adapters, and many to be found online. A good 40mm fan is what I recommend. Summer heat is coming.
I do not like the low profile 40mm fans removed those but here is a pic:
No running Radio Control tall 40mm fans that are 8.4v powered from the ESC. Super powerful
dure16
Illinois
  1. Fireteam
  2. Granite
  3. Infraction
  4. Limitless
  5. Kraton EXB
  6. Outcast 8s
  7. Typhon 3s
  8. Typhon TLR
