2 x 3s is indeed 6s but you can not add the capacity. It will remain at 5200. So the 6S 6800mah should give you a longer run time.So this might be stupid question but…
I have 2 3s 5200mah batteries. In my mind that is 6s 104000mah. Is that right ? I’m looking at a 6s 6800mah.
My question is while I get more run tim out of the 2 3s or the 1 6s ?
Hey Diem!!To round out what the gentlemen were laying down, if you wire your packs up in parallel, then you would double your capacity, but the voltage would remain at 3S. Running packs in parallel, depending on what you're doing, has the added feature of reducing voltage sag under heavy load. While this is typically a feature sought out more in lower voltage speed running than anywhere else, I figured it's useful to know what the various pros and cons are that different battery configurations offer. Happy bashing!
