- Southeast Louisiana
- BigRock 4x4
- Granite
- Kraton 6s
- Kraton 4s
- Outcast 4s
- Outcast 6s
- Vorteks
- Voltage
Hardcase only!
Remove the front retainer if you have to. The strap will still hold it in.F zee lipos 4mm too big only way to mount them is to lift the front retainer up of its lock or remove it
If you remove it, just get another Velcro strap and fish it under the battery tray. I wouldn't recommend running it without the front retainer without the extra strap unless you only plan on lightly bashing.F zee lipos 4mm too big only way to mount them is to lift the front retainer up of its lock or remove it
but I don't think they make 6s hard case batteries at all but i can be wrong ? Because i see picture now ? above in the topic ??Dear Arrmy,
I've just sold my Granite and (hard case 3S) and about to order the V4 Kraton and a battery.
Soft pack 6S batts are considerably cheaper than hard packs.
If soft packs are safe, then why are hardpacks even a thing?
Should I spend the extra to get a hardpack?
My likely usage: park/field runs with jumps no higher 4 feet high, carpark speed runs... so likely crashes will be generally limited to cartwheels and the odd tree that jumps out of nowhere . I will 100% NOT be doing R_duperbash or RCdude81 type driving.
Please kindly advise... I have tried my best to search this forum.
Many thanks.
Ordered them thats what im going to do. those zee lipos look sickIf you remove it, just get another Velcro strap and fish it under the battery tray. I wouldn't recommend running it without the front retainer without the extra strap unless you only plan on lightly bashing.
The retainer is still usable but its not longer clipped in on the side of the baterry tray but lifter 4-5mm from the maximum hightIf you remove it, just get another Velcro strap and fish it under the battery tray. I wouldn't recommend running it without the front retainer without the extra strap unless you only plan on lightly bashing.
Hardcase only!
All are.Even that last one is a hardpack?
I ordered the 4s version but soft pack... I'm I screwed?Hardcase only!
No, soft packs are ok, but they can fold in a wreck or bad landing, if they eject they can also get damaged. That's why I buy hardcase.I ordered the 4s version but soft pack... I'm I screwed?
