6s internal resistance, is this high??
JtkBrew
Bartlett, IL
Charging my 6s 5000mah 50C on my Hota D6 plus charger at 1C charge rate. Are these values high for the resistance?
And is it normal to drop while charging? Below taken a few minutes later than above.
To get an accurate ir you need to deplete the pack to lvc then charge it once it is charged let it get to room temperature then you can take your ir reading.
