Kraton 6s kraton exb front right drive shaft keeps coming out.
Mauzyrock
Hello friends,
My 6s kraton exb front right drive shaft keeps coming out. On hard angular hits. I should not have to remove parts or add parts to solve this. However, here I am, doing both those things. Any suggestions?
Thanks
Mauzyrock rc
Welcome to the forum. Check your droop screw setting and I've heard people in here say to pull the shims out from behind the pillow balls also, I myself haven't had any problems with mine and only thing I did was adjust my droop setting and I actually shimmed to adjust my camber setting, but I am not bashing hard either.
Had the same issue, same side on my Notorious.. I removed the arm end caps and it hasnt popped out since.. 🤷🏻‍♂️
Welcome to the Forum!
Remove the shims like others said, but you can also add nitro fuel hose to the inside of your drive cups to eliminate some travel from side to side. This has worked for me and I usually do this to most of my 6s rigs
