Got a kraton. Same motor and lay out. Im using a dynamite fan with a y harnes of my escWhat motor fan is everyone running on their typhon? Picking up a used typhon this week and wanting to do a fan and few other bashing related upgrades for it.
Fan cost 12$ harnes cost 4$Got a kraton. Same motor and lay out. Im using a dynamite fan with a y harnes of my esc
Whats link for them fans?I once saw very expensive fans that went on 12v for 55 dollar ? and looked at it for a while and made them myself ?.and there crazy gast ?
They guy uses an extra 3s battery to power everything ? but it doesn't need that ? also have no room for an extra battery or weight in my car.
This is a picture of my exb ? but they will put me in my typhon ? and I will do this next week ? because this was a test whether it survives blows and a crash?and it did?
Can you post vid of them running?
You are going to have clearance issues in your typhon unless you chop the body. the easiest setup for the typhon is the yeah racing dual fan heat sink and those fans for some 40x40x10mm fans from another source.I once saw very expensive fans that went on 12v for 55 dollar ? and looked at it for a while and made them myself ?.and there crazy gast ?
ok yeah, it'll fit that body hahahaha. I run 12v ones on mine as well. you can still fit a 28mm under that body at least too. And props for not taking the cheapo ebay $20 bug body approach toodon't worry it will fit because this is my typhon ?
and that fan you propose doesn't compare much to what I made ?
it's 12v what i made ?
If you run mojave arms you’ll have to trim the ears on your chassis in the back or they will hit before the droop screw. Either way you need the turnbuckles and steering linkages/ drive shafts so at that point you could just do kraton parts and hubs. The bigger tires won’t clear the body in a turn on mojave arms. I run them on my street typhon.I'm still thinking about putting mojave arms on it. so that it is just a bit wider and then when they break to outcast teeth.
I have a 4092 in my typhon and the temperature is alright but it is better that a 12v fan goes in ? row quite high pinion ? and 18t is enough ?
also wants slightly wider tires, but that remains a difficult story
