. Motor is a direct drop in for the esc just cut the lip off the esc tray and it will fit just fine with set double sided tape. There are a number of aftermarket ones that allow you to screw the esc to the plate from the bottom, I like the CF ones better than the aluminium just do to the fact they have provisions for mounting the switch.
All my MAX6s are stuck to stock ESC plates. You have to grind or cut the lip off of the ESC plate. I also had to trim the side rail a bit for the motor to fit. Both modifications took me less than 5 minutes to do.
