The question is simple... With the BLX 185 ESC and the 2050KV 6S powerplant that comes standard in the 6S models, what are your options for batteries?
You can definitely run a single 6S
You can definitely run two 3S
You can run a single 4S?
CAN YOU BY CHANCE run a single 2S or maybe a single 3S? (That's important, as if I'd want to run on the indoor carpet track I would absolutely need to be able to run a 2S ((they check voltage).
