Gdub34
Do you guys know if the bottom shock pivot balls on all 4 shocks the exact same. I installed silicone axial bushings in the top holes of the 6s shocks so that’s taken care of. I also bought some 1mm M3 washers to space the driveshafts from the springs. I assummmed the lower stock pivot balls were the same on the 6s and 3s shocksbecause nobody has ever mentioned replacing them and I’m using the bottom 3s screws to connect the 6s shocks to the 3s. The 6s shocks are cleaned and ready to be installed Saturday. Just want to make sure I don’t need any other parts? Thoughts? Thanks
