Kraton 6S V6 Kraton Shock Oil
DannyMak
In the manual it shows stock oil in the shocks is 1300 CST oil. Anyone able to locate this oil online. Cant seem to find any to order. Is everyone using a different weight? Wanting to have some available when I rip the Kraton open for the first time maintenance. Seems like something that should be easily available :dead::oops:
Search for 100 weight, equals 1325 cst
If you have extra silicone oils sitting around that straddle the viscosity you want there is option to mix your own. An online calculator for a desired viscosity.
Does anyone know the oil capacity of the exb v6 shocks? I don't want to dump out the old stuff and not have enough to refill.
Thanks
No problem. The V6 shocks have 1300cst, & I think that's oddball but 80wt is close iirc
One bottle of shock oil is enough to do like 2-3 sets of 6s shocks probably. I built some, fresh, not too long ago, & did all 4 & still have plenty. These were for a regular V5, so I used 1000cst
Was it a 60ml bottle?
