Typhon 80mph 4s fun
K-BASH
ST.LOUIS
  1. BigRock 4x4
  2. Mojave
  3. Notorious
  4. Senton 6s
  5. Senton 3s
  6. Typhon 6s
Mojave chassis mmx8s tp5670-1270kv 40/39/15/42 118mm 1/5 grp senton6 front typhon rear yowoo 6000mah flipped motor mount ram air setup ...mojave center shafts are the longest.ive destroyed them all....1st run on M2C shaft....truck is so fun to drive with the big grps...imo the 1/5 grps are designed for 20++lb vehicles..under 15lbs an I just slid all over the place with the P3s.so I ordered the softest xm1s.much better..warmer the better.its an 4s monster
This thing looks sooo bada$$! 🤩
I'll get a video next time out with it.steamroller tires hook once warmed up..back an forth till pack was dead 80mph.no fan on motor an haven't checked log yet..1/5 typhon???????
No,big gears,big motors,big escs,big packs.this 5670 1270kv motor has sooooo much torque reaching 80 easily on 4s.
I'm guessing being stretched adds some help with control at speed?
Besides the motor you also need a huge pair to do speed runs imo!! HAHAHA
Wow, let me ask ya a dumb Q. to achieve these speeds do they have to be stretched ?
No dumb questions. The only dumb questions are the ones not asked;). Stretching the car also helps you fit those huge motors and ESC's. 1/5 motors are huge and on the SWB cars like the Typhon, there is no way you are going to fit it.
My 8s senton had 5660 1460kv swb.could fit 5670 56×102mm with bigger gear an pps mount
Unbelievably this motor pulled under 200 AMPS on 4s pass...but I did have amp huge spikes from punching it .really gotta be careful not to burn x8s up with to much instant throttle,motor really needs xlx2
