victoroscar
- Infraction
- Typhon 6s
My Infraction 8S won't go past 95mph cause it goes flying every time!Infraction fly away
Listen to this guy ^^^. Also, I recommend buying 16mm droop screws. Didn't realize I needed longer ones until @K-BASH mentioned it. When you set the droop low those 12mm are hanging on for dear life by a few threads in those plastic arms. The moment the front gets higher than the rear at 90+ mph you have yourself an RC airplane.Few pointers.
1. stand in the back of your truck for your safety. People have snapped their leg bones from these cars hitting them. At 95 mph you wont be able to move fast enough.
2. Set the front ultra low using the droop screws. Raz should show in his video that it helps to drill a hole in the upper a-arm to avoid stripping the droop screw.
3. Tighten the rear springs all the way down and make sure the rear is as high as possible.
4. Reduce the rear wing some, but don't fully remove it.
Wow! The first video showed me a lot of things I can do for my Infraction drifter just to make it better even for drift. ThxWATCH these videos
and try adjust like this your rig.
Limitless and Infraction is almost same when you set up chassies
this is a professional speedrunner doing this in videos i link to
and
