I thought I would share an experiment that i'm working on with my arrma 8s rigs. When doing huge sends with the 8s rigs, bending or breaking shock shafts is possible. M2C came out with stronger shafts, but they still do break or bend in extreme cases. This got me thinking of alternatives. I found that the Rovan front shocks are about the same length as the outcast f/r and the kraton rears. They have 10mm shafts and aluminum caps and ends. I ordered a pair to test them out for fitment and functionality. I will keep everyone posted on the results. Here is a link to the ones I ordered.
https://www.rovanrc.com/product-rv853351s
I received them and they are slightly longer but installed no problem. I have not filled with oil yet, and need to rebuild the front of my outcast to replace the cracked gearbox before I can test them out. I am eager to see how they do. Does anyone have suggestions on oil weight? I was thinking 30ish like I run in the stock shocks. because of the larger shafts should I run a different weight? thoughts?
