Arrma Addict
- Minnesooota
- BigRock
- Fazon
- Kraton 8S
- Notorious
- Outcast 8s
- Talion
- Typhon 6s
I am working on my 8s build and will be running Proline Trencher bead lock.If you swap out the front shock tower to the outcast tower, I know the rovan fronts will fit. (I can't comment on fitment when leaving stock front tower installed) The rovan rears fit on the rear but you will want to add 8-10mm tubing spacers inside on the shock shaft to prevent over extending the arms and causing the driveshafts to bind up. Keep in mind it will sit up really tall compared to the stock ride height, and maybe even be overly tall in the rear. Personally if i was going to stay with the base kraton look, and was going to put on rovan shocks, i would change the front shock tower and get 4 rovan fronts. The rears are 3/4 inch longer than the rovan fronts, and the rovan fronts are 1/2 longer than the kraton rear (frt&rr on outcast) That puts the rovan rears a whole inch longer than the stock kraton rears. I could probably mock up the setup you are asking and take a pic, but it will be with the taller shock tower in the front (sorry i don't want to swap out my shock tower to test it ) give me some time. maybe in the next day or so. what tires are you running?
How are you liking this setup with Rovan rear shocks all around?Here's the first run video of the Kraton MT with Rovan rear shocks x4 that I just got done editing. I have ran it a couple times since, but still need to edit those. Enjoy!
