No don"t think so the 8s axle is much bigger......I would like to use the 8s wheel hub (#ARA310928) on the 6s. Will it work?
Ok, is there a way I could upgrade the 6s axle to have them fit?No don"t think so the 8s axle is much bigger......
actually I forgot about these. This is your only option I think tho, you can’t use the actual 8s axlesOk, is there a way I could upgrade the 6s axle to have them fit?
Cool, but I'm looking for something cheaper.actually I forgot about these. This is your only option I think tho, you can’t use the actual 8s axles
https://justbashitrc.com/shop/24mm-wheel-hub-adapter-arrma-6s/
I’m pretty sure that’s it just gonna have to save upCool, but I'm looking for something cheaper.
