CptDestructo
- Kraton 8S
Wondering if anyone else is seeing this issue in their Kraton 8s? There is a lot of longitudinal movement in my front A-Arms where the hinge pin connects the arm to the front block. I don’t know if it came like this or it is due to wear and tear. It seems like the hinge pins almost need to be a larger diameter.
I tried putting washers on either side of the A-Arms where the hinge pin runs through and then reinstalling the hinge pin but that did little to fix the issue and then the arms were binding too much and the suspension wouldn’t work properly.
Any recommendations?
