Outcast a dreaded "where does this leftover part go?" thread
mike k
  1. Outcast 6s
So, I am ending up with two of these little clip things leftover (they look like the little clips in this picture of AR330218 anyhow) after putting my rig back together. Any thoughts on where they should go would be appreciated as I'm not seeing it clearly from the exploded diagram.
At the beginning of winter I took her apart, and just getting back to this now that I have the parts and there is some dirt again. I serviced all three diffs and replaced a servo, so that means I had quite a bit pulled apart. It seems to be a suspension part. I did not remove the suspension arms, but I did take the front shocks off to access the diff, and the sway bars (? - those little paperclip things whatever they are called) on the front.
Thoughts on where these could go would be appreciated :)
