A fairly mega typhon
Grimbles
Certified unintentional RC destroyer
ArrmaForum Fan
Solutions
1
Birmingham, UK
  1. 4x4-Mega
  2. Mojave EXB
  3. Outcast 6s
  4. Typhon 3s
So I finally got round to posting my thread for my Typhon Mega as I have finally got my hot racing diffs!
What I've decided to do is put my pictures in the 2nd post and just spend the 1st post explaining what I've done to her. So from the rear you will see:
1) a Kratonn 6S wing, (unfortunately I couldn't get my hands on another Typhon 4x4 wing)
2) Hot Racing aluminium shock bodies
3) 3S tie rods
4) A gpm aluminium diff yoke holding a hot racing diff case with the helical differential gears and inputs (same up front)
5) 3S aluminium motor plate
6) 3S slipper with the metal 57t spur gear
7) stock Arrma 3S BLX motor and heatsink (20t pinion)
8) 28000 RPM fan
9) 3S shaft carrier and bearing with a 3-D printed flexible cover
10) Hobbywing Max 10 SCT 4S ESC with self made right angled interconnects
11) inside the radio box is the radio receiver for a fly sky IT4S
12) an AQ7 A7 BHM 18 kilo ultra fast servo (tbf it is too much)
13) hot racing server saver,
14) Gpm aluminium steering set
15) Gpm aluminium C hub and Carrier
16) Gpm stainless steel steering tie rod
17) stock Arrma 3S upper tie rod
18) hot racing aluminium shock bodies
19) the same front differential set up as rear
20) RPM rear lower front a arms
21) on all 4 corners duratrax 6 packs
22) rubber sealed bearings everywhere inc in the diff
23) hot racing pivot balls all around
20200919_131311.jpg 20200919_131316.jpg 20200919_131322.jpg 20200919_131332.jpg 20200919_131336.jpg 20200919_131347.jpg
Grimbles
ArrmaForum Fan
Solutions
1
Birmingham, UK
  1. 4x4-Mega
  2. Mojave EXB
  3. Outcast 6s
  4. Typhon 3s
Put cvd driveshafts on today. Will test but think the rig might be getting too heavy. Had bought because i popped 3 or 4 driveshafts on the typhon. Realised i had siezed wheel bearings all over the shop, so think i could well end up going back to plastic. We shall see!
