Handbanana
Hi.
Looking for a good 4s capably motor that will work well with my current electronics setup. I currently run spektrum 3s lipos, a 130amp spektrum smart esc, a spekrtum 3 channel reciever and a Spektrum dx5c smart controller. So its almost entirely Spektrum... I was running a BLX 2050kv motor but i couldn't get the top end i was look for even after maxing out the pinion to spur gear ratio... I did successfully manage to modify a 50t spur gear to run in the clutch assembly but now its too low of a ratio to run right and spacing constraints wont allow me to gear it back up. Honestly 3s just inst enough to push that motor and im trying to stick with the investments ive already made with the 3s lipos... Looking for a 4s motor because i ran into problems with the 3s motors i have... I have both a 3500kv velenium motor and a blx 3200kv motor but Ive run into serious heat issues... to elaborate, before i was running the smart esc I had the blx 100 esc and never ran into heat issues but now with the new esc both motors just cook... don't know why they get so hot with the new esc but they do (yes, i know i should gear down to reduce heat. but its too much heat to begin with)... running the blx 2050kv motor solved the heat issue completely (runs cool ?) but Im looking for more top end performance... So, im looking for that "Goldy Locks" perfect in between motor... Figured something capably of 4s would do the trick... I think my esc is having a problem with the higher internal resistance that my 3s motors have... thats why the 6s motor runs cool... just a guess. Anyway, any sugestions on a motor that would work well with my setup and criteria?
Thank You!
Thank You!
