- Woking, UK
- BigRock 4x4
- Kraton EXB
- Notorious
- Senton 3s
I recently brought a new diff + housing from an unused disassembled V5 kraton and today I set about my rebuild process. But this time I found a new assembly fault. An excess shim - one of the shims used to shim the diff into the housing had been placed between the input pinion and it's bearing. Not only is that the wrong place to put a shim but the size of the shim meant it would have caused all kinds on damage if it had been left there either chewing up the bearing seal, or slipping over the input gear at getting chewed up in the gears. When I first saw if I thought it was some strange bearing design (1st photo) - until I moved it (2nd photo). (As it happens the extra shim was handy as it was exactly what was needed to shim the diff into the housing properly). The bearing was also not seated properly as it had plastic shavings stuck under it - I take it out as I add 2x0.2mm shims behind it.
If anyone is interested this is my rebuild process for the diff internals - all parts are cleaned and thickness measured, then grouped into sets to give most equal thicknesses of the 3 parts combined. The diff housing is also check to confirm that the widths in each direction are equal - this one was, not all are. This hopefully ensures a nice even balance on all 4 spider gears. I have found that I can then add an additional 0.2mm shim on each gear to run as I like it. You can see from the measurements (photo) that putting them together randomly could end up with >0.1mm difference between the largest and smallest set which may be significant if you are trying to run your diffs reasonably tight. When filling the diff oil I also place the output drive gear into the diff and wipe away excess fluid (avoid the screw holes) to get the fluid level just right, then place the crown gear onto it. Some will be interested, others will think I'm just being pedantic and going OTT.
