i put 4S kraton mounts and body on mine, the flat black is uglyHas anyone added a rear wing to their Big Rock V3? Can you use the Outcast wing and mount? I think it would look great with a wing.
i did mine with 3S typhon wing and bracket and put on a Kraton 4S body and 17MM HR hub extenders and proline badlandsHas anyone added a rear wing to their Big Rock V3? Can you use the Outcast wing and mount? I think it would look great with a wing.
yea except i have the original color body and different tires and ZD Racing shocks
Hi @JP3 ,@lycin8008 @leroychurchill @jondilly1974 @L3phturn
Just finished the Outcast wing and the 17mm hex extenders with badlands. Ready to roll... thanks for the help
Is that the typhon rear wing you have pictured? I think the OP wing is a 4s Outcast wing, correct?Don't have to change them. It does sit the truck higher in the back. U can drimmel ur posts down some to drop the stance. I liked mine being raised a bit
They all can use same mount I believe. Its the mega typhon lol. It was a screw up just made it work.Is that the typhon rear wing you have pictured? I think the OP wing is a 4s Outcast wing, correct?
I actually like the typhon 3s wing best. Same mount alsoThey all can use same mount I believe. Its the mega typhon lol. It was a screw up just made it work.
Is this the Outcast 4s wing or a different Outcast model? Anyone know the part numbers for both the wing and mounts needed? I’m having trouble finding it for the big rock 3s v3. Much appreciated.@lycin8008 @leroychurchill @jondilly1974 @L3phturn
I’ve never heard of JustBashIt. Reputable company?
Honestly bud. Im not sure lol. It was first on list when I looked it up. And I do believe ive seen others talk of it. U may check it. But id bet amazon or eBay has the mount 4 sure. Wing is tough sometimes to findI’ve never heard of JustBashIt. Reputable company?
