Billy Magic
- Granite
- Mojave
- Notorious
- Typhon 3s
Hi Everyone,
I'm in the process of completely upgrading my Granite 3s BLX's drivetrain. As the post states I recently put in the Hot Racing front and rear metal diffs and upgraded the composite slipper clutch gear to steel. I also added in a 15T pinion.
My current situation is that when no throttle is applied, the wheels completely lock. There is no roll at all. As a result I keep either
A: lose tension in the slipper clutch or
B: cause the pinion to loosen around the motor.
I have double and triple checked the diffs and they work normally, great even. I used 50k in the diffs but I don't think that would make the difference. It's some problem between the steel spur gear and the pinion IMO, but I can't figure out what's going on. The gear mesh seems perfect to me. I use the "paper" method and it looks good. I've changed this kind of stuff out before on my Notorious without issues so I know how it's supposed to go.
At this point I'm wondering if it's a motor or esc issue. Anyone had a problem like this before or any suggestions?
Thanks in Advance!
Thanks in Advance!
