- Colorado
- Infraction
- Limitless
- Outcast 6s
- Typhon 6s
Getting the new Limitless all set up!! Not quite done yet, being brand new, went through the initial out of the box examination.
All was actually good! So went about putting in the hardware acquired for this rig!
Motor is installed with @PPS-RC Motor mount, so purty! ?
The new Castle 8S ESC. Though not wired up with the motor yet, I noticed that I may be able to use the stock mount screws using a wedging method. So, the design of the new Castle ESC seems to form perfectly with letting the screws heads slightly grab the base of the ESC as you tighten them down, worse case use some washers to help grab more of the base of the ESC. Using this method will help hold the ESC a lil more as a secondary, as I'll be using some good rated double sided tape under it. Along with, so far, the reliable DS3225 Servo from Amazon.
Gonna pair with my RadioLink Tx so had purchased a second Rx a bit ago, just about installed, once the Tx gets synced and the electronics see/read each other.
Using a HW4274 2200KV motor with the 27t Pinion gear to start with meshing with the stock Spool!!
I'll make sure to update when I get everything set, screwed and taped!!
