Senton ADS-7 servo in the mega 4x4.
Stephenmania36
Spokane wa
  1. 4x4-Mega
I have stripped the gears in the stock ADS-5 servo and was curious if the ADS-7 would a direct swap into the mega 4x4. From what I’ve read they have all the same specs, dimensions/connector/spline.
Yes it drops right in, did it today on mine actually!!
just make sure you have the dial on the controller with the notch in neutral, the steering wheel in neutral, then turn on the control and then turn on the car with the new servo plugged in so it will center, then install the servo save as per the diagram on the bottom of the electronics module.
Perfect! Exactly what I needed, I’ll probably order it in a few days and be back up and running. Thank you
