Slim64684
- BigRock
- Granite
- Kraton 6s
This all started with buying a Latrax Teton for my 5 year old for his birthday(4/16). that quickly turned into getting a Kraton 6s for myself(4/23). And as with all new toys I couldn't wait to get it out and play. And play I did. In short time I built a makeshift ramp and started jumping. That led to building a more proper ramp and getting some air under it.
Well as you all can probably guess, that led to repairs needing to be done.
I'm not expert, far from it but I think one of these is messed up. I was pretty sure it wasn't the take off EXB towers i got from JRC( I think that is right, Jennysrc). Only the front was bent, but I went ahead and replaced front and rear. After the EXB towers and only running on 4s everything was good for about 2 weeks.
Then I bit the bullet and picked up two 3s batteries to run 6s, and wow this thing is a whole new animal. I will admit, air control is much improved on 6s and I can land better(most of the time).
That brings us to last weekend, Thursday night to be exact, and I had a bad landing from about 12-15 feet up and popped and steering turnbuckle end. Ordered some replacements and fixed. Also added some snap rings to servo saver to try to tighten steering up. Charged a 4s battery just to check steering and make sure everything and see if steering is improved. Test failed. Full right turn, barely and left. Throw the Kraton back on the bench and start to investigate. Even with servo disconnected, steering binds turning to the left. Started tearing things apart, checking as I go, nothing changes, I eventually pulled the ackerman plate off to see if it bent, and low and behold its slightly arched. To the internet we go and now a M2C ackerman is on the way to pair with a new amazon special servo. I straightened my original ackerman, just to get going, put everything back together and still binding on left turn. Upon closer inspection, my upper a arms don't look the same. Get ready to order some new ones and decided to look again. Dummy me put one on upside down. Flip it and all is good. Now just waiting for servo and new ackerman plate, but i know I'm gonna have to drive it before all that comes in.
And because everyone knows you can't have just one rc, a couple pics of the fleet.
