- Birmingham, UK
- 4x4-Mega
- Mojave EXB
- Outcast 6s
- Typhon 3s
I bought some a4 kids hobby foam sheet and cut and stuck until it was thick enough then wrapped in duct tape! Others may have a more professional approach@Grimbles or others do you happen to have the specs of the approximate thickness of foam pads that work well for the body mounts? Also, does anyone have a link for a set of shims that would be appropriate in case I need them? Are these any good: https://www.amainhobbies.com/arrma-differential-shim-set-fits-29mm-case-ara311094/p1279578
not sure if the Mojave is 29mm diff case?
