MeesterC
I have been waiting on these for so long that I had forgotten that I even ordered these. My initial order for these was in February of 2019 a d from there they kept going on backorder, I finally gave up a d had forgotten about them until a package showed up at my door a couple of days ago. These are the CVD driveshafts that arrma has come out with for the granite blx. First impression was that they look good while they're in the package.....lol. After I took them out and really got to looking at them I wasn't all that impressed especially at $35 a pair. The metal pivot ends are molded into the composite sliders about 3/8 of an inch, the pivot eyelets are thin, the pin retainers on both ends are plastic and the sliders look thinner walled than the stock sliders. I did however switch sliders around, i put the cup slider to the inside and the inner slider on the outside, this keeps dirt and debris from getting inside and causing binding, learned this trick from my crawler rigs. With the cup slider facing down the dirt doesn't collect inside. Anyways back to these CVD's, I was expecting a little more durable looking shafts for the money that was spent. Not really sure as to how well these will hold up over time. I'm running the hobbywing ezrun max10 sct brushless combo with the 3200kv motor on 2s and 3s and yes I play hard with it. The eyelets on the ends look really thin, almost like they will snap or break easily, the end that attatches to the differentials is also plastic and held on with a grub screw. I don't know, to me these just feel cheap for the money. I'm pretty sure that in time either the picot end will break or pop out of the composite case but only time will tell. I have attatched plenty of pictures for all to see and you can also see how I flipped the sliders around. Let me know what you guys and gals think. Does anyone else have these? I'm running these on front and rear.
A few more pictures.
