After market tires “Felony”
harvey
Michigan
  1. Felony
I’m looking around to see if there now any aftermarket tires/rims for or tires alone for my tire eating machine.
Want to get some before I start bashing I looked around and seen the ones that comes with it gets ate up fast, I wanna get some better ones if possible.
Proline has the only other option and they have way more grip than hoons but also last a little longer
Yes, can use without changing the rear diff. And they are $costly$. Because they are PL Licensed Proxes treads Mounted on stocker Arrma Hoon Spoker wheels. HH owns Proline now FWIW. And PL stuff is alway expensive in general.
You don't have many other choices for a proper drop in replacement with the Felony in it's stock drivetrain configuration.
Fronts:
https://www.prolineracing.com/produ...belted-mounted-17mm-5-spoke-2/PRO1019910.html
Rears:
https://www.prolineracing.com/produ...belted-mounted-17mm-5-spoke-2/PRO1020010.html
BTW, stocker Hoons for the Felony also come in harder or softer compounds. Silvers and Gold respectively. FWIW. Stockers are White compound. Look into them. Same price as stocker Hoons. Silvers are harder and "might" last a bit more. Depends how you drive. These chassis will always eat tires. Is what it is. I only speed run and they last way longer. Any tires will. When my tires get old and worn/bald I might drift with them till they blow out. I try to get my moneys worth out of my tires.:LOL: But I mostly enjoy speed run passes.
For just bashing Hooning around ( Not dedicated speed running), makes no sense to spend a lot on tires. The Proxes might be $overkill$.
Most tires will get trashed anyway quickly just Hooning it, drifting around.
Fronts:
Rears:
I totally agree, I am mostly a speed runner as well but I also like to make everything as tight as possible to get the most out of the machine.
