odraciRRicardo
- Kraton 8S
- Kraton 6s
- Typhon 6s
Hello good people,
This weekend I got my hands on a Kraton 1/5 EXB which I paired with the Hobbywing Max5 + 800kv combo.
Using the 39/39 gearing. Incredible beast.
I'm having some heating issues with the ESC.
Is there any aftermarket fan I can use for it?
If I look for one do I just look for the correct dimensions? Assuming it's a more powerful one, how do I know if the BEC can output the necessary amps?
As for the motor, do you use any cooling?
Any brackets available to mount fans? I wasn't lucky finding any for 56mm.
Heatsink is probably not essential as the motor itself is already ribbed forpleasure heat dissipation.
Thanks for the help.
