- South Louisiana
- BigRock 4x4
- Granite
- Kraton 6s
- Mojave
- Notorious
- Talion
- Typhon 6s
Excellent! ?Okay here's a pic for illustration purposes using some garbage wltoys shocks I swapped out on a different truck. Shock on the left is the original length of this shock for comparison and shock on the right has an 8mm nylon spacer on it. Install a spacer of whatever length you want to take out of the travel onto the shaft before inserting it through the shock body during reassembly. Then add your rod end, oil, and bleed like normal etc and you're done.
