Air compressor and Cleaning
BashingNBreakin04
Outcast 6s
jondilly1974
Speed running rookie, 3D printing fool
Toledo, OH
Granite, Kraton 4s, Typhon 6s, Typhon 3s
adidas303
Rocky Mountain High!
Colorado
Infraction, Outcast 6s, Typhon 6s
Man, you're making it difficult for me to not spend money!! I was thinking about one of these as well for painting and cleaning purposes....
I'm hoping many more respond to learn a bit more on them as well. That one listed seems very nice at a darn great price too.
BashingNBreakin04
Outcast 6s
This was so me, probably everybody else too. 😂
JtkBrew
Bartlett, IL
Kraton 6s
For just cleaning purposes or air tools, I don't feel a water filter, dryer, or trap is necessary. If your going to paint with it, I would suggest some method of removing the moisture coming out of the compressor. You don't want that moisture in your airline mixing with the paint.
Even though the compressor is oil free, most air tools do recommend you add a drop of oil to the tool air inlet prior to every use. Read your tool manual for confirmation.
Also, you'll want to open the valve on the bottom of the compressor tank once in awhile to let any moisture out of the tank. This prevents the air tank from rusting from inside out.
A compressor is a great tool to have in your garage. There are countless things I do with mine. Trim work, framing, air up pool toys, top up tires, blow out the garage, clean the RCs. They're very convenient.
jondilly1974
Toledo, OH
For just cleaning purposes or air tools, i don't feel a water filter, dryer, or trap is necessary. if your going to paint with it, I would suggest some method of removing the moisture coming out of the compressor. You don't want that moisture in your airline mixing with the paint.
Even though the compressor is oil free, most air tools do recommend you add a drop of oil to the tool air inlet prior to every use. Read you tool manual for confirmation.
All good advice. 👍🏻
