bicketybam
Back from vacation!
- New Milford, CT
- BigRock 4x4
- Granite
- Infraction
- Kraton 8S
- Kraton 6s
- Kraton 4s
- Mojave
- Notorious
- Talion
- Typhon 6s
In July it will be two years since I purchased my first Arrma 6S, the Arrma Kraton. I thought this would be a good time to express my thoughts. Please note that mine is a V3 and it came with the Tactic radio system. Since you can now only get it with the STX2, I will use that in my review.
I find the Kraton to be a very capable monster truggy, but it has some areas that need to be addressed. My truck came with dBoots Minokawas and I can say that I really didn't care for them at all. I bash mainly on dirt and grass. Traction was average to below average on those surfaces. On pavement it was fine. I tried many different tires over the 2 year period, from Proline Trenchers to Shockwaves to dBoots Backflips to what I currently run now: the now standard Copperhead 2's. I really like the Copperhead 2's and if you are buying a V4 you should be very pleased with the tires.
The current version comes with a radio that is been widely reported to be very poor. I have no experience with it and I never really used the Tactic it came with. But based on what I've read, the Tactic is much better. Either way, factor in a new remote just like every other Arrma truck except the ones that come with the DX2e.
I upgraded to RPM A-arms almost immediately. It's really hard for me to give an accurate assessment of the stock arms. It's also worth noting that I was a terrible driver when I got the truck. The Talion uses the same arms and I kept those stock. I've had no issues but I'm a much better driver now. My advice would be to keep the arms stock and see if you break them. I set the limit at 2 before I would commit to the softer RPM arms that tend to warp. I've had to replace a full set because of warping.
The chassis is fine for the average basher. But I have a saying: If you send the chassis will bend ? That's a fact. I've bent every factory 6S chassis. I eventually replaced it with an M2C chassis. If you like to jump your Kraton, this is almost a must upgrade
The plastic chassis braces are terrible. They must be replaced with aluminum ones, even if you have an aftermarket chassis. 7071 flexes and will snap the plastic braces. Then you bend the front center dogbone. This should be your first upgrade.
Bearings are metal shielded. They should be replaced with rubber sealed. The stock bearings will seize quickly unless you only run on pavement and in dry conditions. Actually make this your first "upgrade."
Shock towers are ok. Again this will come down to your driving ability and your type of bashing. See my earlier rule: send = bend. I bent mine early on and went with Voltage Hobbies. Now your best options are M2C and JBI. Hot Racing aren't that good.
My truck came with the V3 diffs which meant too light of oil and no shims. I went through several front and rears due to driver error. The V4 diffs come shimmed and the center diff has heavier fluid. You still need to check all the diffs for the proper amount of fluid and since you should be changing the bearing anyway, this should be done at the same time. I have V4 diffs in my Talion and I didn't add any extra shims. No issues. How long a diff lasts depends on driving skill. Landing on power/brake, self righting, and improper standing backflips will kill them. They are not bulletproof (or idiot proof ?).
The front bumper is inadequate for most beginners. I went with am RPM front bumper almost immediately and it's still going strong. It's worth noting that I run the stock "bumper" on my Talion and it's been fine. Again, driving skill factors in here.
I upgraded the stock servo to an expensive Savox. The stock servo isn't terrible but it isn't great. There are cheaper options for servo upgrades now and it's a decent investment. The truck has big tires and needs a decent servo to turn sharply. My truck came with the V3 servo saver. While it is know to loosen over time, I find it to be better than the servo saver on my V4 Talion. The new servo saver is not easily adjustable. If you can find a V3, go for that.
Stock electronics are fine. I never had an issue with the BLX 185 in my Kraton. It did run hot on the speed pinion but a fan can fix that. I eventually went with a Max6 and a Hobbystar 4092 1730 kv motor. It also needs fans. But the truck is more than capable with the BLX185 system.
The steering blocks and rear hubs are adequate. You shouldn't have issues unless you wreck hard. I went with what I think is Hot Racing's best 6S Arrma product: aluminum steering blocks and rear hubs.
The stock steering rack (Ackerman plate) will bend on the first one front wheel landing. It's cheap 6061 aluminum. See my earlier rule about sending and bending. Go with the M2C if you want to jump. Or you can just wait until it bends.
The wing mount isn't bad at all. The trick is not landing on it ? Do not get an aluminum one. RPM will break with a big hit just like the stock one. People have suggested boiling the stock one. I never have and once I learned how to not land on the wing it has been fine.
I upgraded my servo mount because they was the group think at the time. @Jerry-rigged has a good solution for the stock mount which basically calls for longer screws through the chassis. I think an aluminum mount is a luxury upgrade and not necessary.
I've had great luck with shock rod ends and the stock standoffs. Yes I've broken them both but I'd say they were deserved. It's important to set your droop properly. You can upgrade to the HD Nero rod ends (or Tekno) but I don't think it a must. M2C makes upgraded standoffs but I've seen them break too (right, @Outcastblxnut?).
I've upgraded all of the suspension mounts. Did I need to? No. I would do these if you have a problem repeatedly breaking them. M2C has a really nice solution.
Shocks have been fine for me. They do their job and work well. You can get better performance out of them with the M2C pistons but casual users won't notice the difference. Luxury upgrade for sure.
Stock pillow ball retainers cross thread easily and the V3 version would tend to back out. My Hot Racing steering blocks/hubs came with their retainers and they are awesome. I run the M2C retainers on my Talion (it has the stock steering blocks/hubs) and they also work very well.
The V3 body wasn't very durable. The rear body posts would always tear the rear mounting holes. The new V4 body and body posts are different and it helps to a degree. You really need to reinforce the body, especially if you bash hard or terribly ?
There is a lot of slop that is inherent to all the Arrma trucks. They are bashers, not track stars. There are mods to tighten it up but I am fine with it. The 6S trucks do steer better than the 3S/4S trucks.
I think that covers everything but if I missed something or if you have a question please feel free to chime in ? Overall I am very pleased with the Kraton 6S. If you are just a regular casual basher it really doesn't need much besides metal chassis braces and rubber sealed bearings. If you like to go big or if you struggle with your driving (or both!) it will need some upgrades. People will debate if it's a better value than the Tekno kits because if you go full on upgrade with the Kraton it's pretty close to the cost of the Tekno kit with a basic radio and electronics. Personally I don't regret buying it one bit. It really does everything well and is considered the king of the 6S lineup. While I love my Talion, it would be hard to argue against the Kraton. If you understand your driver skills and know of the Kraton's few weaknesses, you will be very pleased with your purchase. I know I am ???
