Big Rock Almost what I want
DetroitSS
Michigan
  1. BigRock 4x4
  2. Infraction
  3. Limitless
  4. Typhon 3s
My little Big Rock 6S is getting a little closer to what I want now.
17mm wheel hubs[taken off of my parts typhon]
One of my set of hoons for my infraction
Spektrum SR6100AT reveiver[paired with mydx5]
Hot Racing motor mount
Steel 57t spur[locked]
26t pinion
Hobbywing 150amp and 2100kv motor from my Redcat Kaiju[converted the Kaiju to 3s for relaxing bashing in backyard]
Gens 5000mah 60c 6S battery[had to print a 1/4 inch tpu battery riser for battery]
Had to print a little thicker and sturdier high speed driveshaft support[the stock one was moving a lot]
And then my TPU wing and wing mount.
About 70% throttle as I live on a pretty narrow street and have'nt got that gutsy yet. Need to finf some good speed run areas here in SW Detroit.
Would you share??
Sure I don't remember the number where I got them from. I can email you the files or something if you like. Yep i will have to send it to you this file is'nt on thingiverse anymore. I will be more than happy to send them to you.
NVM your in luck I found it. www.thingiverse.com/thing:4781126
Sorry old thread just wanted to say that was very nice of you sharing your files with someone else..🤟😁👍
