Alternative wheels & tyres to dBoots Katar
Steve Brx
Talion
I'm frustrated by the quality of the standard Katar tyre and wheel set on the V3. They are completely out of true for example, and wobble left to right due to the fact the wheel walls are very thin and easily distorted due to inconsistent tyre gluing.
I'm looking for better quality, and have naturally looked at PL Badlands / Desperado combinations. However, these are wider than the Katar's by 10mm's and I'm keen to retain the original tyre dimensions (145mm x 59mm).
Does anyone have any recommendations?
stuartd
Scotland, UK.
Talion, Typhon, Notorious
Sorry to hear your Katar's sound like they have issues. I still use mine on my Talion, now that they're slicks they're great for on road handling.
I use dBoots Backflips off road and Road Crushers on road. Only thing that's needed with the backflips is to drop ride height, or the Talion wants to wheelie too much.
Primarrma
ArrmaForum Fan
Australia
Kraton, Talion
I was wondering the same, do you so much jumping at all?
I found the mass isn't enough to really bring the nose up in the air?
I was thinking of trying a heavier tyre, but I don't want to change the dynamics too much.
slick2500
Will work for beer.
ArrmaForum Fan
Rapid City, SD
Outcast, Typhon
Dang I never realized how narrow the Katars are.
So far everything I have found is either wider and shorter or wider and taller.
Duratrax Xcons are the closest I have found so far to being those dimensions they are 144mmx64mm but they are not the best on 6s Duratrax tires like to turn into dinner plates https://www.towerhobbies.com/cgi-bin/wti0001p?&I=DTXC3660
Yonic
ArrmaForum Fan
Philly, PA
Senton, Talion, Typhon, Voltage
Any racing truggy tires would be close, like the Duratrax @slick2500 suggested.
The best bashing option i found is the Louise Apollo. It's basically the same size as the Katars, but they have more sidewalls, so more dampening.
Similar threads
