Picked up some aliexpress alum 3 bearing rear hubs....yikes tolerances...should've gone with gpm?
one hub isn't very bad, just acceptable for cheap. the other is BAD and will likely bore out the bearing seat in no time.
the bad hub has bad tolerances in all directions too. sucks because i bought these thinking they would reduce slop...literally only reason, even at expense of more weight (much more).
anyways iy does have a much larger inner bearing, uses the normal inner bearing as a middle bearing, and the outter is same size.
the tolerance is bad enough on all that the bearings don't "seat" in place, just drop in / drop out. the worst hub the bearing can actually rotate / wiggle within bearing seat lol...what's more is at least 1mm to narrow; meaning wheel moves in / out about 1 mm...that's with one diff shim on outer bearing.
anyways, these 3 bearing aliexpress 6s rear hubs are an avoid imo
