Aluminum Pivot ball set
Hey everyone,
I need to replace my pivot balls in my steering and bell crank. Looking for the blue aluminum and found these blue sets for an axial rc. I am assuming they might work but not a 100%. Would someone steer me in the right direction.
HRASCP160B06 Hot Racing Aluminum Pivot Ball Set (Blue) (20)https://www.amainhobbies.com/hot-racing-aluminum-pivot-ball-set-blue-20-hrascp160b06/p508754
I am assuming that you want some for your 1/10 Arrma? I have both an SCX10-II and a 1/10 Arrma and I can check to see if the stock pillow balls from the Axial will work in the Arrma.
That is a negative sir, the Axial pivot balls are much smaller.
Arrma pivot balls are 9.6mm long and 6.8imm in diameter
I have the armma granite 3S. I found some red aluminum that will work, but I have been getting blue aluminum upgrades and want to stay with that color. Eventually I will get swap for a longer LWB chassis
Hey everyone,
I'm coming up with a diameter of 6.9mm and a length of 10mm. So I don't think so. You can try. The worst you will be out is $15.
Edit: Don't waste your money as per Slick.
Well shoot!! thanks for the info.
On closer inspection the Arrma has 3 different size pillow balls. The ones I gave the measurement for are the largest of the 3.
The largest ones are for the turnbuckles. The tiny 2 are for the arm that connects to the servo saver/horn. The rest are barrel shaped and are for the shocks.
Is your sig The Amazing Horse?
