I went the HR Aluminum shock body kit route as most the other options listed in the post were sold out. The HR bodies kit worked out very well though so I am happy with them should you also be curious about them.What Aluminum shocks can I use for typhon 3s?
I was wondering about this. Initially I was going to use 80 weight based on forum suggestions but decided to do 60 weight instead. What did you end up choosing?I ended up using the 4s shocks with the hr aluminum bodies.. they are 6mm longer than the 3s line... I made a 6mm spacer for the shock shafts that sit under the piston to get them back to the 3s length... they work well, but net to also be spaced at the bottom so the spring perch doesn't rub the shaft and arm.. I also noticed the hr bodies have a tighter tolerance where the piston fits in the body, requiring lighter oil than i typically use...
I may change it to 35 though...I was wondering about this. Initially I was going to use 80 weight based on forum suggestions but decided to do 60 weight instead. What did you end up choosing?
