Here’s my Mojave. I just installed a M2C chassis and I found a much better fan for the HR heatsink that runs on 24V.
Sweet build. I’m really eyeing a Mojave ?
dang nice
I noticed the tires are well worn, like my Mojave V2. What about upgrades for the stock Mojave wheel/tire combo. There there anything out there that would be a step up?New setup is a BEAST. Motor did not go over 155F even with hard throttle for 15 mins straight (6S). This should leave me with plenty of thermal headroom if ambient temps spike again. The stock system was pretty much useless on a 105F day. I have a radar gun coming in the mail that I hope to get speed readings with.
I replaced my Savox SB-2273SG CE with a Futaba S9373. The Savox was a carryover from my Kraton and while it’s got plenty of torque I felt it was too slow. The Futaba at .06sec/60 is lightning fast. I also have a GYC441 gyro tucked into the rx box and I can't believe how well it tracks with the gain turned up.
Currently running 19/50 gearing, seems to be plenty fast for me.
I think this covers most of the stuff on this truck that isn't stock anymore.
Futaba 4PM / R334SBS
Futaba S9373SV
Futaba SBS-01V Voltage Sensor
Futaba SBS-01TE Temperature Sensor
Futaba S.Bus Hub
Futaba GYC441 Gyro
Hobbywing MAX 6 ESC
Hobbywing 4985 1650kv motor
Hot Racing XMX505F06 X-Maxx Fan Mount
TRA3362 X-Maxx heatsink
eBay 50x50x20mm 24V fan (item #402324383885)
Hot Racing Aluminum Diff Case x2
Hot Racing Aluminum Steering Block
Hot Racing Aluminum Rear Hubs
Hot Racing Gearbox Case Bulkhead Cover x2
Hot Racing Aluminum Center Differential Cover EZM Mount
Hot Racing Aluminum Center Differential EZM Mount
Hot Racing Aluminum Center Sway Bar Mount x2
Hot Racing Aluminum Center Brace Rear Mount
Hot Racing Aluminum Center Brace Front Mount
Hot Racing Aluminum Rear Lower Front Suspension Arm Mount
Hot Racing Aluminum Rear Lower Rear Suspension Arm Mount
Hot Racing Aluminum Steering Servo Mount
Hot Racing Aluminum Bearing Steering Bellcrank
ARA330216 steel sway bar balls
Arrma option shock boots
EXB Front Chassis Brace
EXB Rear Chassis Brace
EXB Front Upper Suspension Mount
EXB X-Hard Servo Saver Spring
M2C Chassis
M2C Rear Chassis Brace
