I got the 17mm ones in the front and I really like the size. Here are two pictures for referenceLooking at adding some angel eyes for front and rear lighting on my Infraction. What is the size recommended size to go with.
Thanks.
Thanks for your response. I went ahead an ordered two sets of 17mm angel eyes. Should be arriving today. The size looks great. Not too big nor too small. I was looking at the 22mm size. Thought they looked big. Did you just glue them in place. Would have been nice had come with mounting hardware.I got the 17mm ones in the front and I really like the size. Here are two pictures for reference
View attachment 138614View attachment 138615
Those blue eyes looks crazy with the blue body. awesome. Thanks for responding. What did you do for mounting, hot glue?
I tried to keep the hole as tight as possible, so you only have to press them in and they will hold. But they would probably fall out at higher speed because of the vibrations. So I just used some hot-glue on the inside and so far it has been working great for meThanks for your response. I went ahead an ordered two sets of 17mm angel eyes. Should be arriving today. The size looks great. Not too big nor too small. I was looking at the 22mm size. Thought they looked big. Did you just glue them in place. Would have been nice had come with mounting hardware.
Yes, hot glue (quite a bit to keep those leds horizontal).Thanks for your response. I went ahead an ordered two sets of 17mm angel eyes. Should be arriving today. The size looks great. Not too big nor too small. I was looking at the 22mm size. Thought they looked big. Did you just glue them in place. Would have been nice had come with mounting hardware.
That's awesome. A friction fit with some hot glue sounds just about right. Don't want too many complications getting these installed. Do you have them plugged into your receiver or running on a separate battery.I tried to keep the hole as tight as possible, so you only have to press them in and they will hold. But they would probably fall out at higher speed because of the vibrations. So I just used some hot-glue on the inside and so far it has been working great for me
Thanks. Sounds like hot glue will work just fine.Yes, hot glue (quite a bit to keep those leds horizontal).
Kind of in between. I have a cable which comes from the receiver box and this cable attaches to the body mounts and is hold there with some tinfoil.That's awesome. A friction fit with some hot glue sounds just about right. Don't want too many complications getting these installed. Do you have them plugged into your receiver or running on a separate battery.
Hi,Kind of in between. I have a cable which comes from the receiver box and this cable attaches to the body mounts and is hold there with some tinfoil.
I have it the same way on the body and by doing that I can just put on my body without connecting any wires
Mine are from Amazon as well. I didn't check the voltage but I run them on 7.5V as well. So this shouldn't be a problem. If you have two AUX channels you can plug them in 1 and 2. Otherwise a Y splitter is needed.Hi,
I installed both set of lights tonight. A nice tight fit with some hot glue did the trick. I have a question. I picked these angel eyes from Amazon. They have a input voltage of 4.2V to 6.0V
My stock BEC voltage is set to 7.4V. Is this going to be okay to plug them into my receiver for power. Also I can use either AUX 1 or 2 right.
I will have to pick up a Y splitter to power up both sets.
The install turned out quite good.
