biggman100
- Fury
- 4x4-Mega
I initially thought this issue was servo related, but, i have since changed the servo that was in it, and the issue didnt go away, so, i tried both Servos in my DHK Hunter, and didnt have any issues, so, now im stumped. The issue is, when i am at a dead stop, or just going slow, and i turn, the truck, for lack of a better way to put it, stutters, almost like it is cogging, and has even completely stopped a couple times, but, at anything from half throttle and faster, it doesn't act up at all. Anyone have any idea as to what it could be? About 3 weeks ago, i used all new parts, although they are the original metal gears, and not the newer composite ones, and rebuilt the diff, and filled it with 30K Traxxas oil (go ahead, im already prepared for the, Traxxas killed it, comments), but, it was fine until maybe a week ago, then it started this stuttering it is doing now. I also replaced all except the motor bearings with rubber shielded ones recently. Could the motor, since i have barely cleaned it all summer, let alone reoiled it, be the issue? It has a Castle Sidewinder ESC and motor (the green can one, i forget the specs at the moment), that has been used hard. I have even had it completely submerged for a few seconds a couple different times (there is a culvert at the end of our road that fills with water, and i just cant resist blasting through it), and, i have also played with the slipper setting, but that was more to tame some of the wheelspin on certain surfaces, but i have been messing with the slipper for about a month now, so i don't think thats it, since its pretty much back to where it was initially. When i took the servo back out, just to make sure it wasnt a battery issue, i put the battery from the Fury in the Hunter, since i only ran it maybe 5 minutes, and, until it hit LVC, it didnt act up at all, so i am at a loss as to what it could be.
