LiamG
this should help you fix the issueGuys, I’ve got another issue with my truck. The front end is extremely sloppy and I can’t figure it out no matter what I try. I’ve upgraded the servo saver spring to exb along with a c-clip, hot racing bellcrank with shims on the posts, exb Ackerman bar, upper exb hinge pins and an exb servo mount. My front end is still wobbling like crazy in reverse and is noticeably sloppy just shaking the wheel by hand. The left side seems to be worse than the right side…. The only obvious issues I see are the upper a-arms have a little play in them and the Ackerman bushings are slightly loose in the exb Ackerman bar. Has anyone had similar issues and if so, is there something I’m overlooking?
